06-13-2018 14:56 - last edited on 10-18-2021 16:51 by EdsonFitbit
Can I wear this on one arm and then change to the other mid day? Or is that going to mess everything up? Or is it fine if i just update the setting?
Moderator edit: added label
06-13-2018 15:26
06-13-2018 15:26
@frop1 wrote:Can I wear this on one arm and then change to the other mid day? Or is that going to mess everything up? Or is it fine if i just update the setting?
Yes, but you should change the Wrist setting to the opposite wrist.
06-13-2018 15:26
06-13-2018 15:26
