Fitbit pay and PIN
Can i set up a pin and fit bit pay on my Versa if it is not a  limited addition ? Thank you
1 REPLY 1
If you live in North America then, no, you need the Special Edition Versa for it to have the NFC chip inside the watch.  If you live anywhere else in the world, then, yes, you should have the NFC chip and you would be able to set up FitBit Pay.  You can check the back of your Versa in the teeny, tiny print around in an oval.  if Fitbit Pay is listed, then you can set up Fitbit Pay.  You would need to have a credit card from a participating bank and be physically in the country where the card is issued to do the set up.
https://www.fitbit.com/fitbit-pay/banks
Kathy | USA
Versa SE, Charge 2, Samsung Galaxy S10+
