05-11-2018
22:37
04:23
YojanaFitbit
05-11-2018
22:37
04:23
YojanaFitbit
Does beats. Connect with versa via. Bluetooth
04-10-2019 11:44
04-10-2019 11:44
Guys! Do it this way just this person said! I turned off my Bluetooth and it worked!!! Don't give up and please try this!!!!!
Best Answer04-20-2019 06:47
04-20-2019 06:47
I have tried this many times and my Fitbit Versa will not connect to my beat solo 3 even though I have tried everything
Best Answer04-20-2019 06:52
04-20-2019 06:52
How have you solved it
Best Answer12-20-2019 10:18
12-20-2019 10:18
BUT, it is not finding my Powerbeats 3...very frustrating
Best Answer12-20-2019 10:19
12-20-2019 10:19
Mine do NOT show up either HELP
Best Answer12-20-2019 10:21
12-20-2019 10:21
I tried turning them off also BUT DID NOT PAIR it is very frustrating. I also have a fitbit Ionic and my powerbeats will NOT bluetooth with it either.
Best Answer12-22-2019 12:10
12-22-2019 12:10
doesn't work
Best Answer12-22-2019 12:56
12-22-2019 12:56
Do you know that for a fact? I should give up?
Best Answer12-23-2019 06:47
12-23-2019 06:47
The first time you do it will give trouble be persistence
Best Answer01-01-2020 11:20
01-01-2020 11:20
Hi,
I have paired my beats with my versa 2 and can even operate my music via Spotify with my watch, however, when I start my run and get far enough away from my phone my music doesn’t play. Very frustrating! Any suggestions?
Best Answer01-01-2020 11:24
01-01-2020 11:24
Best Answer02-19-2020 17:05
02-19-2020 17:05
Thank You!!! This final worked to pair the Ionic & my Beats.
Best Answer05-28-2020 11:36
05-28-2020 11:36
This worked for me! Thank you!!!
Best Answer07-21-2020 10:34
07-21-2020 10:34
I struggled at first but was able to get them to synch up with my versa 2 by pressing the little button on the inside of the headphone charging case for several seconds. It made the charging light blue. This is for the Beats Pro true wireless headphones. Hope this helps
Best Answer09-14-2020 06:02
09-14-2020 06:02
I cannot. Bought beatsX earphone. Cannot pair with versa. Cannot find the device when do a search device.any one could advise
Best Answer05-10-2021 15:49
05-10-2021 15:49
I've been wondering about that too. Aren't the Bluetooth earbuds/headphones/speakers supposed to pair to the Fitbit Sense/Versa without the need of having a phone within a few feet of both devices? Because I don't want to go on runs with my phone right on my arm or close to my body in general for an hour or two hours of running.
Best Answer05-24-2021 21:14
05-24-2021 21:14
Were u able to find a solution. I can’t pair my beats to my watch and I can’t get Spotify to work either. My watch is telling me to start Spotify on another device and then it should work on my watch and nothing
