06-21-2018 08:14 - last edited on 06-22-2018 08:40 by HeydyF
I wanted to go for a run this morning (first time with my new Versa) and had no problem pairing my airpods. I started running with music working perfectly fine from my airpods. However after only 100metres the airpods disconnected from my versa and stopped playing. Whut? I heard a lot of crackeling noise and had to stop my exercise.
I tried repairing them but the problem doesn't seem to solve itself.
Anyone having the same problem? I am seriously considering returning my airpods.
06-22-2018 08:40
06-22-2018 08:40
Hey @SunsetRunner, it is nice to see new faces around! I appreciate that you have tried to unpair and repair your Airpods to fix this disconnecting issue. Beside that, I'd like you to try the following:
- Unpair and repair your airpods again
- Make sure that your watch is on the same side as the receiver on the headphones
Let me know how it goes!
06-22-2018 12:36
06-22-2018 12:36
I have exactly the same problem!!!
when I start running I hear the crackeling noise and the music stops...I am checking Versa settings the airpods are still connected and the music seems to play but I hear nothing..I have to pause and play to hear but when I start running guess what ?MUSIC STOPS again!!!it is really frustrating...
06-23-2018 05:24
06-23-2018 05:24
Hey @Antonio23, welcome aboard! I'm sorry to hear about the inconveniences you have with your Versa and your Airpods. Let me ask you this, have you tried the tips that I posted above? If you haven't, please give it a try and let me know how it goes.
I'll be around!
06-23-2018 07:42
06-23-2018 07:42
already done the steps so many times nothing changed...I think it's a versa software bug or something..
07-24-2018 14:37
07-24-2018 14:37
It’s not the airpods that are at fault it’s the Versa. Fitbit are working on it ☹️
07-24-2018 14:42
07-24-2018 14:42
The same problem with Fitbit Ionic. It must be a software problem, because the 2 watches are very alike.
07-25-2018 05:05
07-25-2018 05:05
Fitbit released an update this morning- I haven’t tested my air pods with my Versa yet but I’m hoping the problem is resolved.
07-25-2018 07:35
07-25-2018 07:35
It didn’t resolve the issue ☹️
07-29-2018 00:21
07-29-2018 00:21
The Versa doesn't work reliably with Airpods and they cut out frequently.
One odd thing I've noticed is that when they cut out if you go to the music control app on the Versa and hit pause then play, you instantly get the sound back.
07-29-2018 04:02
07-29-2018 04:02
07-29-2018 06:06
07-29-2018 06:06
I agree. Maybe wire free bluetooth headphones need a stronger signal than regular bluetooth heaphones. (Airpods work perfectly for running with an Apple Watch, btw.)
It would be great if Fitbit could let their customers know if:
(a) they are aware of a problem with their product and the Apple Airpods
or
(b) They feel the problem is with the Airpods
07-30-2018 22:44
07-30-2018 22:44
The problem is still there after trying what you suggested. Is Fitbit working on the problem? Cause it seems to be the Versa that is acting up when pairing to my airpods.
11-25-2018 02:37
11-25-2018 02:37
It s nov and j still have the same issue. Just got mine from Black Friday and now I m think of returning jt and getting a Apple Watch 😭
11-26-2018 06:04
11-26-2018 06:04
Hey @moonchild100, it is great to see new faces around! I can't guarantee that they will work but you can give a try of the following tips to avoid this from happening again:
Keep me posted!
11-27-2018 11:41 - edited 11-27-2018 11:43
The Versa just doesn't work with AirPods and I was going to send it back because of that.
However, the alternatives are: Apple Watch (doesn't cut it as a fitness tracker and has pitiful battery life), Garmin (overpriced and cheap-looking), generic Android watch (fragmented market, big depreciation due to the constant product changes). So... I sold my AirPods instead.
I like the Versa and I think Fitbit are doing a lot right. I hope they have a future; it seems unlikely with the current pace of innovation.
11-27-2018 12:27
11-27-2018 12:27
Thank you for the info. I really hope they can provide a solution to this... i will still need my airpods when i'm at the gym using with my phone... maybe i will just get some other wireless earbud just for outdoor running... Any recommendations guys?
11-27-2018 12:43
11-27-2018 12:43
Personally, I find the way the cable on reguar bluetooth headphones bounce around annoying. My solution was to buy a Flipbelt and use my wired apple headphones. The cable tucks neatly into the belt and because I have to carry the phone for the GPS, I figured I may as well used it for music too.
