06-20-2018 14:43
06-20-2018 14:43
I wore my new fitbit to bed to track my sleep, and every time I moved the light came on and woke me up. This is not helpful.
Can I set my fitbit to a sleep mode or turn off the light for the night?
06-20-2018 14:57
06-20-2018 14:57
Go into the app, touch the device in the upper left corner to get to the settings and about 2/3 down there is an option for "Quick View". Turn it off.
06-20-2018 16:49
06-20-2018 16:49
@Heather3842 wrote:I wore my new fitbit to bed to track my sleep, and every time I moved the light came on and woke me up. This is not helpful.
Disregard the instructions rsava just gave you! On the Versa, press the left button for several seconds to bring up the Screen Wake Setting and set it to Manual.
06-20-2018 17:29 - edited 06-20-2018 17:29
Or don't disregard the instructions rsava gave her and note that there is a second way. I grab my phone and look at the app immediately upon waking in the morning so it is much more likely that I would just do it there.
There are more than just YOUR way to do things, you should learn that so you don;t sound like such a jerk. That is certainly what you sounded like this time.
06-21-2018 07:21
06-21-2018 07:21
Heather, I'm sorry if you are all confused about this with conflicting answers to your question. Since you have posted in the Versa Forum, I'm assuming your question is in regard to the Versa. And the correct answer to your question is the one I gave you. The Screen Wake setting is on the Versa itself.
rsava, your answer applies to the Charge 2, for example, but not to the Versa. We can do without your derogatory references to other posters.
07-03-2018 09:14
07-03-2018 09:14
THANK YOU!!!! I had to stop wearing my Versa to bed because it was causing more sleep problems. I did what you suggested and it worked. Your instructions are correct for Versa.
