06-20-2018 23:44 - last edited on 06-21-2018 04:09 by AlejandraFitbit
Hi everyone, I bought my Versa 2 months ago. I went swimming last week then was at a wedding so didn't wear my Fitbit. I put it on charge when I returned home but the display is not working properly and I can't see anything? Anyone help?
09-18-2018 01:43
09-18-2018 01:43
Hi,
I went swimming the other day and after I noticed my Fitbit Versa stopped tracking my Hear rate. Next day screen went black and I am not able to turn it on since then. I tried to charge it as I thought battery run out but id till does not turn on and does not respond.
I also tried to hard reset with holding two buttons but it does not work.
What to do?
09-18-2018 06:46
09-18-2018 06:46
10-29-2018 13:20
10-29-2018 13:20
Same problem, even later! Why has this not been fixed? No results from customer service, will attempt return tomorrow.
10-31-2018 13:35
10-31-2018 13:35
I even been having the same issues with mine (turning off randomly, battery life horrible, refusing to turn on, sync, or charge)! Called customer service today & they are replacing my Versa AGAIN for the second time in 6 months. This is absolutely ridiculous. You’d think they would have fixed this issue by now. I’m so mad because something told me to go with the Apple Watch originally. When the replacement comes in I’ll be giving that one to my daughter. I just went ahead & bought myself the new Apple Watch yesterday. It’s a far more superior product. It’s such a shame too because I’ve been with Fitbit for the last 5 years. I never again spend any more of my money on these crappy watches! Once the rest of my families devices break that’s it! I don’t see this company lasting much longer if this is the type of quality products they keep putting out. Shame on you Fitbit. You know these Versas aren’t working as they should. Also, don’t even think about getting them wet!
10-31-2018 13:46
10-31-2018 13:46
10-31-2018 13:47
10-31-2018 13:47
Agreed! & this issue is not "solved" if it keeps happening! Sending out another of the same unit a week to 10 days later (when I've only been using a Versa 2 weeks!) doesn't really change much, now does it????
12-03-2018 02:52
12-03-2018 02:52
I just did the first step and works fine now! Thank you so much!
12-13-2018 08:03
12-13-2018 08:03
I have the same issue after 2 week of bought it.
I try shutdown and hard reset (hold 2 and 3 buttons). But it isn't solved.
12-13-2018 09:37
12-13-2018 09:37
12-27-2018 07:29
12-27-2018 07:29
I went to change clock faceon Versa( had it 1 month) and it doesn’t swipe up down or across. Called customer support getting a new one in 5-7 days. No charge
12-27-2018 07:31
12-27-2018 07:31
Took me 5 minutes after talking to representative at Fitbit. Went through reset and other solutions. Nothing worked. New one
coming soon. Great customer service!
01-01-2019 12:03
01-01-2019 12:03
I'm frustrated. I'm having the same problem with my Versa. It vibrates, and the green LED on the back blinks, but the screen won't turn on. I've tried all the suggested restarts and resets.
I've had failures with Alta HR, Blaze and now Versa. I love my Fitbits, but I need a device that I can count on to work each day.
01-01-2019 14:05
01-01-2019 14:05
01-01-2019 14:23
01-01-2019 14:23
My Versa is working. I can take steps and see the update in my iPhone app. However, the screen is black. Searching through this message board and other sites, it appears that many people have similar problems.
01-04-2019 13:22
01-04-2019 13:22
Any chance of talking in general on this problem? Been searching trying to fimd the awnser to this problem and this is the closest i got.
01-04-2019 16:11
01-04-2019 16:11
I called Fitbit. The Versa needs to be replaced. I'm sending them the broken one and they will then send me a replacement.
01-05-2019 01:28
01-05-2019 01:28
01-05-2019 07:19
01-05-2019 07:19
01-05-2019 07:27
01-05-2019 07:27
I also got the same display issue on my Versa since this morning. Not sure what is going on with these firnwafi updates
01-05-2019 07:30
01-05-2019 07:30
