07-10-2018 12:46
07-10-2018 12:46
Today used my versa for a pool swim, not the first time I have, and at the end the buttons stopped responding and are still not working. Did a factory reset and will go to alarms screen automatically. Since buttons not working can't back out. Have had this since April 17th first time I have had problems.
07-10-2018 14:34
07-10-2018 14:34
You could try really drying out the device by putting it in white rice. My sister dropped her phone in a lake once and put it in white rice afterwards and it worked perfectly.
If that doesn't work, I would contact Support immediately.
one cruise ship at a time!07-11-2018 05:48
07-11-2018 05:48
Thank you, it seems to be working better now probably dried out. It is frustrating though since it is supposed to be ok for swimming.
10-02-2018 16:28
10-02-2018 16:28
Same is happening to me!! I hate it’s happening since it was supposed to be used in the swimming pool!!
10-02-2018 16:33
10-02-2018 16:33
It’s gappening to me the back button won’t work and it’s vibrating for jo reason keeps waking me up!!!
10-02-2018 16:43
10-02-2018 16:43
10-02-2018 22:45
10-02-2018 22:45
10-03-2018 07:54
10-03-2018 07:54
01-15-2019 10:52
01-15-2019 10:52
Same here. Notification screen was poping up with no notifications. Vibrating out of nowhere waking me up.. button unresponsive. Went through support and got replacement. Meanwhile the old one stayed out of water and stopped having this problem. So that definately was the problem. Now they reason i bought this after having charge2 for only 6 months was the waterproof ability.... and now im scared to use even the replacement (which was not new as a device, it was used when they sent it and at worse state than mine) underwater. At least they do replace within warranty.
