Search instead for
Versa not counting steps and not holding a charge
Hello,
Ever since yesterday, my Versa will not count steps and has a problem holding a charge. I've factory reset it, restarted it and it still won't work.   Is there anything that can be done?
Thank you.
Accepted Solution
Hey @kreezy, welcome aboard! Smiley Happy Thanks for trying to factory reset and restart your Versa. I'd like to ask you something regarding the steps, is it not counting your steps at all or is it not counting them accurately? In the meantime, I'd like you to take a look at the following help article that explains how Fitbit trackers count steps.
Now in regards of the not holding battery issue, I'd like you to take a look at the tips in this post to make the battery of your Versa lats longer.
Let me know the outcome!
Heydy | Community Moderator, Fitbit
Accepted Solution
It's not counting steps at all, and as far as the battery is concerned, it worked fine and then now it glitches.. it used to hold a charge for 2 days at a time but now it doesn't even last a day before I have to charge it and I have done nothing different.
Accepted Solution
Thanks for your reply @kreezy! Since you still getting issues with your Versa, I have escalated your case to our Support team so they can further assist you with this. So please keep an eye on your inbox. Smiley Wink
Let me know how it goes!
Accepted Solution
Thank you.  I haven't heard from support and my Fitbit still doesn't count steps at all.  I don't know what else to do.
Accepted Solution
And you probably won't hear from support. It's been 2 weeks and crickets. My advice and it sucks if the watch is not returnable is to do what I  did.  Get a Garmin. Works great.
Accepted Solution
That's exactly what I said.  I'll never buy anything but a Garmin again.  I'll give it to my daughter so she can use it for the watch.
Accepted Solution
