09-17-2018 07:48
09-17-2018 07:48
So the screen wont turn on, but I know the watch is on based on the app (it shows my battery level being medium). Also, on the back there's a flickering of both green and red lights. I've tried charging it and restarting it but nothing happens. Any ideas on how I can fix it?
09-18-2018 03:12
09-18-2018 03:12
I would try restarting it few more times to see if that helps. Other than that you only have a few options left to try.
You could let the battery die and then try charging it to see if the screen comes on.
Then there is a hardware factory reset which you can perform following the steps below.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If none of these work your only choice will be to contact customer support.
09-18-2018 03:12
09-18-2018 03:12
09-18-2018 05:04
09-18-2018 05:04
09-18-2018 13:03
09-18-2018 13:03
Hey @Caaneelaa, let me give you a warm welcome to the Community! Is the screen of your Versa turning on now? Did the tips that @N8teGee suggested, helped you out? If not, let me know and I will continue assisting you.
I'll be around!
09-18-2018 13:03
09-18-2018 13:03
I'll be around!
09-18-2018 13:41
09-18-2018 13:41
The three button didn't help either
09-21-2018 05:38
09-21-2018 05:38
Hey @beefsthunder, I hope you are doin' great! Thanks for trying to restart your Versa to turn it on. Let me ask you this, is it your Versa completely dead or when you plug it into the charging cable, can you see that is charging?
I'll be around so please let me know!
09-21-2018 14:09
09-21-2018 14:09
09-21-2018 16:41
09-21-2018 16:41
Hey man! It did work, I thought the display had stopped working, but it's working now. Thanks for the help guys
09-22-2018 07:34
09-22-2018 07:34
Thanks for the information @beefsthunder! Since your Versa display won't turn on, I have escalated your case to our Support team so they can further assist you, so please keep an eye on your inbox.
@Caaneelaa, sounds good that your Versa is working again. 😉 I appreciate the update.
Keep me posted guys!
09-26-2018 02:29
09-26-2018 02:29
HI! My fitbit Versa was working fine. Yesterday the screen went blank, i tried rebooting post seeing all options on the discussion forum. It is currently working as the sync with my Samsung happens everytime I try. However, the screen is still black. I am unable to see anything at all. Additionally, I do not know how to track my workouts now. This is a huge challenge as the versa is linked to my fitness studio also. I have also tried changing the clock face as pressing all 3 buttons or just two buttons as advised in the forum to restart and reboot. Nothing worked. I sent an email to customer support with an image of the versa screen.
Please help on an urgent basis.
09-26-2018 05:58
09-26-2018 05:58
09-26-2018 12:39
09-26-2018 12:39
09-28-2018 11:16
09-28-2018 11:16
Hey @beefsthunder, I hope you are doin' great! I appreciate the time you have taken to contact our Support team. And sounds great that they have replaced the previous one and get you back on track.
@SunsetRunner, I'm pretty sure that our team will find a solution for this. 😉 Keep me updated!
I'll be around!
04-29-2019 10:56
04-29-2019 10:56
I have the black screen issue, as well. Once I was able to get it back on with a charging sync. Then a second time 1 day later now, nothing. I also tried the factory reset 3 times, nothing. The unit still records and bluetooth updates my samsung, but only a black screen. It's less than 18 months old. Any new tricks?
04-29-2019 11:01
04-29-2019 11:01
04-29-2019 11:19
04-29-2019 11:19
My Versa screen is also black. I tried the 2-button reset a few times...no luck.
I did the 3-button factory reset many times...no luck.
The Dashboard cannot link to the tracker.
The battery shows half-charge, but will not charge any more.
This will be a year old on Mother's Day.
Please advise.
05-12-2019 06:36
05-12-2019 06:36
Mine has a zero percent icon when you try to reset. It won't charge, reset or doing anything. App shows medium battery. Will be returning today 😢. Tried everything. Very disappointed.
06-08-2019 23:42
06-08-2019 23:42
Hi so my versa was working all day but suddenly the screen stopped working I try to restarted it but it didn’t work. I charge it and it did nothing as well. I am getting notifications because it vibrates what can i do ?
07-09-2019 02:01
07-09-2019 02:01
That is exactly what happened to me yesterday, my battery was low, so I charged my watch and it synced when I took it of charge. It showed that it was fully charged and later the evening the screen was not responding. I tried everything with no response and now it is not syncing anymore. What else can I try?
