04-16-2018 18:41 - last edited on 08-19-2018 16:50 by AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
05-28-2021 17:53
05-28-2021 17:53
Hello everyone, thanks for your participation in the Community.
Thanks to all for the efforts to resolve the issue, sharing the solutions and steps you've tried. I understand how you are feeling about this situation and if you're experiencing this issue, please follow our tips in this help article: Why didn't my Fitbit device alert me? You can also try restarting your device: How do I restart my Fitbit device?
If the issue persists, the best way to get help for this problem is to chat with our Support team online or give them a call. Click here to get connected.
I am going to close this thread, but if there is anything else we can help you with, do not hesitate to start a new topic.
Have a nice day.
04-17-2018 16:37
04-17-2018 16:37
Welcome to the Forums @Dd1186! Thanks for sharing your experience with the notifications feature on your Fitbit Versa. First, I'd like you to check if the vibration of your watch is working correctly.
To do so, follow these steps. On your watch, open Alarms. You’ll see your next scheduled alarm (if you set one).
Next, test your watch's vibration motor:
If this doesn't work, please restart your watch to ensure that it works properly.
Keep me posted!
04-17-2018 19:37
04-17-2018 19:37
mine was doing the same thing.
I unpaired it through my phone Bluetooth
removed it from my fitbit app. Uninstalled fitbit app.
Turned off Bluetooth
reset versa
Reset phone
Installed fitbit app and added versa. Turned on Bluetooth through the fitbit app when prompted.
Turned notifications for text and everything else on and now it vibrates with notifications.
I'm not sure which step fixed it but something did, lol. Hope it works for you!
04-18-2018 07:31
04-18-2018 07:31
I have the same problem. I followed your steps and reset the watch; it still doesn’t vibrate or alert me when I get notifications. What else can I do?
04-19-2018 16:52 - edited 04-20-2018 10:24
Thanks for the update @Jbolling! Good to hear that you are back on track. I really appreciate that you have shared the steps that worked for you. This can be beneficial to other users experiencing a similar situation.
Also, I'd like to encourage you to join us at the Discussions board, there you can be inspired, find some tips to get moving, eat well, manage weight, sleep better, live mindfully and more! Give it a look! 😉
Welcome to the Forums @karlancha! Thanks for sharing that you tried the troubleshooting tips that I shared. In this case, I'd like to suggest you to setup your watch as a new device. You can follow the tips in this Setup Guide.
Keep me posted with the outcome! 🙂
04-20-2018 06:39
04-20-2018 06:39
I excitedly received my Versa yesterday and am now realizing I rely greatly on the vibration feature. I've missed several calls and texts.
I've tried all the steps suggested with no luck getting it to vibrate for the alarm, timer, text or phone calls. Any other suggestions before I return it?
04-21-2018 18:43 - edited 04-21-2018 18:44
Mine vibrates for texts and calls but vibrations is much much weaker than my charge 2. Nothing is happening at all when I meet my goal on Versa though which is disappointing.
05-02-2018 09:38
05-02-2018 09:38
I got my versa on Mon and can only get the vibration to work occasionally, the alarm didn't work this mirmorn and none of the movement reminders or bedtime reminders have ever worked. I have done a hard reset and deleted the app, then reset everything (now the Bluetooth is doogy) and it hasn't helped. Also now my location can't be found
Ready to return the watch didn't expect this hassle
05-06-2018 13:20 - last edited on 05-07-2018 09:19 by AlejandraFitbit
Hey,
This started today, whenever I receive a notification (Facebook messenger, SMS text, etc.) I see the notification on my Versa but there is no vibration ... I already did everything, reset my phone, reset Versa, unpaired with Bluetooth, factory reset versa, uninstalled Fitbit app, etc.
The vibration on Versa is working, I did a test with an alarm clock and in settings (changed vibrations from normal to strong). My phone is not in DnD mode. What else can I do?
Thank you for your help.
05-07-2018 09:21
05-07-2018 09:21
A warm welcome to the Community @nimr0d.
Thanks for troubleshooting this by yourself. Since the steps you tried didn't work, I've gone ahead and escalated your case to our Support Team for them to take a deeper look at this, please keep an eye on your inbox for further instructions.
Catch you later.
05-23-2018 06:53 - last edited on 05-23-2018 06:56 by AlejandraFitbit
I am having the same issue with my Versa. I did all of the suggested resets also. Any suggestions? Was your issue resolved? I am having the same problem.
05-23-2018 10:27
05-23-2018 10:27
I think it needs to be fixed via firmware. I have the same issue, resets don't make sense if every other feature is working
05-24-2018 03:01
05-24-2018 03:01
Hi,
Had this problem, my fitbit versa suddenly stopped vibrating on notification, tried all of the tips here.
Then I realised.
If you hold the left button you can turn off notifications from your wrist, and then other night I had done just this from the cinema!
Useful feature, when you remember to turn it back on again!
05-28-2018 05:47
05-28-2018 05:47
When I pull down the messages I see them but there is no vibration. The vibration is on. I have an iPhone. Turned off Versa. Went into Bluetooth settings to forget device. Went back into notifications when I turned on app and Versa to reinstate notifications ... still nothing
05-28-2018 06:19
05-28-2018 06:19
Does it vibrate at other times, or is there no vibration at all?
Helen | Western Australia
05-28-2018 10:20
05-28-2018 10:20
Do you maybe have any tattoos there?
05-28-2018 12:53
05-28-2018 12:53
Yes it does ... it vibrates to alert me to make 250 steps an hour
05-28-2018 12:53
05-28-2018 12:53
None ... wow .. would that matter ?
06-06-2018 08:26 - last edited on 06-07-2018 04:38 by AlejandraFitbit
I am receiving notifications but my Versa is not vibrating to alert me. The only way I know is if I swipe down and see them or through my iPhone. I have went to the notifications tab on the app and the ones I want notified on are selected. Any suggestions?
06-07-2018 04:45
06-07-2018 04:45
A warm welcome to the Community @faithk0124.
Thanks for troubleshooting this by yourself. If your Versa isn't vibrating, I recommend checking if your "Device Lock" is enabled or disabled by doing the following from your Fitbit app:
If it is enabled, do the following:
I hope this helps, let me know the outcome.
