05-08-2018 11:02
05-08-2018 11:02
I realise that the OnePlus 3 isnt supported by FitBit but has anyone used the phone with the Versa? Specifically does the connected GPS and notifications work.
05-08-2018 14:22
05-08-2018 14:22
Hiya, I've got OnePlus 5 which is not on the compatible list and notifications and gps work fine, the only notifications I don't get are calendar ones but from what I've read there's numerous other people in the same boat. I've put on a calendar app on for now and moved it to the front of the app queue on the watch so I can use the buttons on the right hand side to launch the calendar
05-08-2018 14:47
05-08-2018 14:47
That sounds good anyway. The main thing I would use it for anyway would be the GPS and notifications.
06-15-2018 15:04
06-15-2018 15:04
I took back the ionic because I couldn't get it to sync with my oneplus5 - a phone I really like and don't want to buy a phone on the supported list just for fitbit reasons. Looks like you got your versa to work well enough. Did you use any particular workarounds or did you follow the usual directions? As a pebble fan I'm thinking of moving to the versa.
Any advice would be appreciated.
Thanks!
06-15-2018 15:09
06-15-2018 15:09
06-15-2018 15:29
06-15-2018 15:29
06-20-2018 05:21
06-20-2018 05:21
Hi, i have just purchased my first fitbit and spent ages trying to set it up with no success. i called the helpdesk who told me that my phone (oneplus X) isn't supported and that in a short period of time i won't be able to use it at all in conjunction with the versa.
so it seems pretty pointless having the versa at all, the problem being that i have purchased it now, opened it and so won't be able to send it back.
the guy at the helpdesk was not very helpful so i am not sure what it means if the phone won't work with the versa anymore. presumably i won't be able to see the steps information, get call notifications etc?
any advice would be gratefully received, i am really not happy at all and wishing i had never wasted my money on the thing. not a great introduction to fitbit products 😞
Thanks for any help!
07-05-2018 20:45
07-05-2018 20:45
You can setup using Windows 10/ Mac PC and see all the steps information synced to your dashboard.
you can even install the app in your phone and see the updated dashboard synced but what you really can't use is the notifications from mobile to fitbit.
07-05-2018 22:30
07-05-2018 22:30
Mine is one plus 3t and I don't have problem with sync over Bluetooth, so I got no problem with notifications. the only problem I got is wifi connection. For whatever reason, I can't connect to wifi (2.4 ghz) though I followed everything from what fitbit recommend.
