04-21-2018 15:59
04-21-2018 15:59
Hi i purchased my versa yesterday. I cant connect it to my wifi at home. I have paired it with bluetooth and can see it as an avaible device in my fitbit app. I use a Samsung s8. Any help would be great
04-21-2018 16:18
04-21-2018 16:18
Try using your phone as a hot spot. And connect to that WiFi network.
04-24-2018 17:33
04-24-2018 17:33
I'm having the same issue, have you figured it out?
04-24-2018 17:46
04-24-2018 17:46
Your troubles may be part of the server problem that Fitbit has had all day.
04-24-2018 17:47
04-24-2018 17:47
04-25-2018 01:05
04-25-2018 01:05
10-01-2018 11:05
10-01-2018 11:05
My not so Fitbit is taking an age to connect to home WiFi. I’ve switched it on and off and no luck. Anyone have any bright ideas for me phuleasee.....
