03-17-2018 01:30
03-17-2018 01:30
Hi Fitbit,
I really love the look of the new versa however disappointed to hear it doesn't come with GPS as it as EVERYTHING you could want in a tracker. I have looked at Garmin but where they fall short is not having music available through the watch and the coach feature. Will the versa be launched with GPS?
Thanks!
03-17-2018 02:00
03-17-2018 02:00
No @Sangs the Versa wont have inbuilt GPS though it will utilise connected GPS, so as long as you have your phone, you can still track your route.
03-17-2018 01:38
03-17-2018 01:38
Have you checked out the ionic? It has the same functions as the versa and has built in GPS.
03-17-2018 02:00
03-17-2018 02:10
03-17-2018 02:10
Thanks SteveH....yes I had a look at the ionic but don't really like the look at feel it's really bulky and harsh but I really like the versa.
03-17-2018 02:19
03-17-2018 02:19
don't forget that one of the reasons the versa doesn't look so bulky is that it doesn't have built-in GPS. It seems to be a choice between smaller, cheaper but no GPS or bigger, more expensive and with GPS
03-17-2018 10:51
03-17-2018 10:51
On the Versa product spec page under SPECS it lists under "sensors and components", second to last Item GPS?? See below. Implies it has GPS or Fitbit is being misleading? I was about to pre order it...
03-17-2018 10:56
03-17-2018 11:02 - edited 03-17-2018 11:09
@SunsetRunner how odd... This is what I get and I am using chrome
https://www.fitbit.com/uk/shop/versa
03-17-2018 16:03
03-17-2018 16:03
Thanks....I was really hoping not to have to take my phone using this watch. Do you know what information about your run it will give if you don't take your phone with you?
03-17-2018 16:12
03-17-2018 16:12
@Sangswrote:Thanks....I was really hoping not to have to take my phone using this watch. Do you know what information about your run it will give if you don't take your phone with you?
It will track steps, heart rate, calories, duration, distance, pace and average pace. Obviously the distance and pace will be calculated using your steps and stride length.
04-13-2018 22:44 - edited 04-13-2018 22:45
The limited edition has the GPS feature, the one that cost $229, not the Original one price at $199 🙂
04-13-2018 22:58
04-13-2018 22:58
No, it has NFC. Not GPS. Your answer is wrong.
04-14-2018 08:53
04-14-2018 08:53
You are correct. No GPS in the Versa SE. Adding GPS to it would have raised the price well over $30.
05-01-2018 10:45
05-01-2018 10:45
Yes but coming from a girly perspective, the ionic is ugly. If the versa had gps I would buy it today.
05-03-2018 03:29
05-03-2018 03:29
Hi there. Just jumping on your post. Im looking to buy a fitbit versa. Im not intrested in having gps. However, can I still use the 'activites' wihout gps?
05-03-2018 03:32
05-03-2018 03:32
@MeganHafJones wrote:Hi there. Just jumping on your post. Im looking to buy a fitbit versa. Im not intrested in having gps. However, can I still use the 'activites' wihout gps?
Yes the Versa will track your activities without gps
05-03-2018 03:32
05-03-2018 03:32
Will the 'activity run' still allow me to track my run without gps? Im worried that I will purchase the watch, only to find out I HAVE to take my phone with me
05-03-2018 03:34
05-03-2018 03:34
I was just concerned that if I selected a GPS activity, that I'd have to use the GPS. Are you confirming I can skip setting the GPS and I could still have a record of my tracked run/walk?
05-03-2018 03:55 - edited 05-03-2018 03:58
The Versa will track your activity but not your route. So HR, steps etc. If you want route / map, you’ll need your phone, as the Versa will use the phone’s gps to track your route, as it doesn’t have its own gps.
just to confirm, you can turn off connected gps in the activity settings (small cog)
