05-09-2018 13:44
05-09-2018 13:44
Hi!
I am switching from Charge 2 to the new Versa fitbit and I am wondering how to switch the device without losing all my data and history?
Thanks!
05-09-2018 17:23
05-09-2018 17:23
Hello @Emma0303
When you set up the new one, tell the app that it is a replacement for the other Fitbit. Your history is kept on the server, under your email address, so it remains the same. Just be sure to sync one last time from the Charge 2 before setting up the Versa.
Congrats on the new FItbit!
05-09-2018 17:32
05-09-2018 17:32
You can keep both of them connected to the same account, but as @Odyssey13 mentioned, you will need to sync the device you are currently using before you switch. Just go to your Account Settings in the app (or Dashboard if you're using a computer), which looks like a little credit card and is located in the upper right hand side of the screen. Select "Add New Device" and then "Versa". From there, follow the prompts and your Versa will be added to your account.
Now, if you had the Ionic and then got the Versa, you wouldn't be able to use this method. You would have to set up one as a replacement for the other.
one cruise ship at a time!05-10-2018 09:27
05-10-2018 09:27
You should be able to add the Versa and then continue to use the Charge if you want. Fitbit has multi-tracker support. So you can wear the Versa one day and the Charge the next.
https://help.fitbit.com/articles/en_US/Help_article/1715/?q=multiple&l=en_US&fs=Search&pn=1
