I just started to develop with Fitbit devices.
I want to post Alarm to my devices ,so I wrote a code.
Here is the code
import json
import requests
headers = {
"Authorization": "Bearer secret",
"content-type": "application/json"
payload={"time":"09:00-09:15","Enabled":'true',"recurring":True,"weekDays":"MONDAY"}
url = '<a href="https://api.fitbit.com/1/user/-/devices/tracker/example/alarms.json" target="_blank">https://api.fitbit.com/1/user/-/devices/tracker/example/alarms.json</a>'
r=requests.post(url,data=json.dumps(payload),headers=headers)but it returns
{"errors":[{"errorType":"validation","fieldName":"recurring","message":"Recurring is required"},{"errorType":"validation","fieldName":"time","message":"Time is required"},{"errorType":"validation","fieldName":"enabled","message":"Enabled is required"}]}
I can't fix it.How do I to fix it?
Hi @takepan ,
I'm not that familiar with python. Here are a couple of things to consider
1. the "devices" scope should be enabled
2. you can add alarms for trackers, not smart watches (Ionic and Versa family)
3. check the case of the parameter name and the value. I think they should be all camel case.
The URL should look something like this
Best AnswerSorry but it doesn't work. It returns 500 error.
{"errors":[{"errorType":"request","fieldName":"500","message":"An error occurred with the Fitbit Web API while processing the request. Error id: A29E072D:B50A_A92D87A6:01BB_5CB13337_4E1B7C7C:3E55"}],"success":false}How do I fix it?
To enabled the alarm for multiple days, you need to do 2 things
1. parameter "recurring=true"
2. parameter "weekDays" list the days of the week in all capital letters separated by comma, no spaces.
Here's an example
We have this information documented here: https://dev.fitbit.com/build/reference/web-api/devices/#add-alarm
If you're still having a problem, please include the URL you are executing.
