403 Forbidden Writing Weight Data – Works Until May 20, Only Weight Fails (Steps/Calories OK)
We're encountering a persistent issue when calling the Fitbit Web API to write weight data using the endpoint:
POST /1/user/-/body/log/weight.json
Starting from the evening of **May 20, 2025**, this call consistently returns `403 Forbidden`. Before that, it had been working reliably for months.
**Platform & Scope Info:**
- Client ID: 22C4KQ
- App Type: Server (recently changed from Client)
- OAuth Flow: Authorization Code Grant (server-side)
- Affected Platforms: Both iOS and Android
- Token Scopes Granted: SETTINGS=READ_WRITE, PROFILE=READ_WRITE, WEIGHT=READ_WRITE, ACTIVITY=READ_WRITE
Token introspection confirms all scopes are active.
**What's Working (Confirmed):**
- Reading weight data via GET /body/log/weight.json
- Writing steps, calories, and distance data (via /activities.json)
- Reading profile, activity, and settings
- Fitbit user account is functional with other third-party Fitbit apps (writing weight still works there)
**What’s Not Working:**
- Only `POST /body/log/weight.json` returns 403 Forbidden, even with proper request body and valid token
**Hypothesis:**
We suspect Fitbit recently added additional restrictions to writing sensitive health data (such as weight) based on app identity (e.g. client_id-level policy). Our app may now require whitelisting or explicit approval.
**Request for Assistance:**
1. Was there a recent backend policy change affecting `/body/log/weight.json`?
2. Does our app now require additional authorization to write sensitive data like weight?
3. What is the formal procedure to apply for this level of access?
Any guidance is appreciated. This feature had been functioning as expected until May 20.
Thank you!
0 REPLIES 0
