01-07-2016 15:28
01-07-2016 15:28
I am having an issue with the Authorization Code Grant option.
Here is what I am doing
My callback returns a querystring paramater code=xxxxxxxxxxx
i set var code=xxxxxxxxxxx
xhttp.open("POST", "https://api.fitbit.com/oauth2/token?grant_type=refresh_token&refresh_token=" + code + ":" + "65483fe9d4747672afd2f9f2112008ac", false);
var auth = window.btoa("ClientID:Clientsecret");
xhttp.setRequestHeader("Authorization", "Basic " + auth);
xhttp.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
xhttp.setRequestHeader("Accept", "*/*");
xhttp.send();
It returns a 400 error
{"errors":[{"errorType":"invalid_grant", "message":"Authorization code invalid or expired: [code]."}],"success":false}
Help!!!!
Best Answer01-22-2016 21:20 - edited 01-22-2016 21:58
Two things here.
1. The app first calls on https://www.fitbit.com/oauth2/authorize? (as you have done in your step 1).
and get back an authorization code.
The app POSTs the authorization code and asks for an access token and refresh token.
(You are not doing this.)
The app gets back an access token and a refresh token.
The app POSTs a request for fitbit data using the access token.
Later, when the old access token expires after 1 hour, the app asks for a renewed access token using the refresh token.
(You appear to be doing something like this without asking for the access token and refresh token first.)
2. Not sure about the line
Seems that the quotes might be mucking up there, thus:
var auth = window.btoa("2244WGA" + ":" + "abmpq13589dda84920");
where ClientID = 2244WGA
and ClientSecret = abmpq13589dda84920
Hope this helps.
Regards,
Tony Barry
[edited for typos, clarity]
