Hi, I'm trying to issue the following request which seems completely in-line with the API docs:
POST /oauth/access_token HTTP/1.1
Host: api.fitbit.com
Authorization: OAuth oauth_consumer_key="cc67ee9e1533462ca7f2ffde6aa41300",
oauth_token="48ba7e3ce619bf38e155e3482ec59759",
oauth_verifier="epqlig2jcvohlv16l9ec3ujp13",
oauth_signature_method="HMAC-SHA1",
oauth_signature="w52OZgcHyjYFI14jx3SxaCIW3c4%3D",
oauth_timestamp="1405010464",
oauth_nonce="A79D3475-183C-434C-8FEA-5DEFE96109DE",
oauth_version="1.0"
However I get back the following:
{"errors":[{"errorType":"oauth","fieldName":"n/a","message":"No Authorization header provided in the request. Each call to Fitbit API should be OAuth signed"}],"success":false}
Can you tell me what I'm doing wrong? Tried this a million different ways and the APIs are not cooperating.
How are you making your request?
Although you're seying your passong quthorization and everything looks good, the fact that it responds with "No Authorization header provided in the request. Each call to Fitbit API should be OAuth signed" means Authorization header from you.
Best AnswerThe problem was that the signature didn't match; I forgot to add the verifier into the signature body. The error message was just a generic message. Might want to consider adding a special error if the sig doesn't match.
When you pass invalid signature it returns to you different error that states that your signarure is incorrect.
Could you please reproduce behaviour with CURL and sopy and paste your CURL?
