06-26-2017 05:54
06-26-2017 05:54
Hi ,
I am using fitbit developer api to fetch users steps data for 7 days using curl. For that we have cron job.
But it takes lots of time to execute (for 85 users).
Below is the code am using:
1. First i am requesting api for new accessToken for each user :
$url = 'https://api.fitbit.com/oauth2/token?grant_type=refresh_token&refresh_token='.$refreshToken;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,$url);
curl_setopt($ch, CURLOPT_HTTPHEADER, array('Content-Type: application/x-www-form-urlencoded',
'Authorization: Basic MjI4NE5OOjU4YzFmYTIzMzg5OTMxZTAzYjUyODFkMzcyMDAwOTQx'));
curl_setopt($ch, CURLOPT_RETURNTRANSFER,true); // return into a variable
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($ch, CURLOPT_POSTFIELDS, true);
$result = curl_exec($ch);
2.Using new AccessToken again am calling api requesting steps data for each user :
$url1 = 'https://api.fitbit.com/1/user/'.$accountId.'/activities/tracker/steps/date/'.$currentDate.'/7d.json';
//echo $url1;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,$url1);
'Authorization: Bearer '.$access_token));
Is there any way through which i can call api for refresh token for all users(85) at a same time.
Similarly i want to call api for steps data for all users(85) all at once. Is this possible? Can you provide me proper guidance for the same.
