01-29-2018 04:34
01-29-2018 04:34
I have a problem with an Application I registered yesterday - the Client Secret field remains empty .
I registered an Application on https://dev.fitbit.com/apps with OAuth 2.0 Application Type "Server" . I understand this field is required for the Authorization Code Grant flow.
I can see all the other fields and I also have an option to Reset Client Secret (which does not seem to do anything)
Is there anything special that needs to be done / configured to get this Client Secret field visible?
Thank you!
Adam
Best Answer01-30-2018 13:22
01-30-2018 13:22
There is an issue with the secret generation right now, please add a comment in this thread.
Best Answer01-30-2018 13:23
01-30-2018 13:23
Moved to the Web API forum.
