I am currently pulling data from Daily Activity Summary (https://dev.fitbit.com/build/reference/web-api/activity/) and have several questions about the following fields:
Hi @sleepy_dave,
Apologies for the very late response.
@sswift Thanks for the suggestion, we are aware that this is a widely requested item and is being considered.
I hope this helps. Please let me know if you have any other questions.
Best AnswerI've been searching for the same thing, and @JohnFitbit I appreciate your response here, but it doesn't seem to be accurate. Here's what the Fitbit Activity API reports for me for yesterday (omitting other fields):
https://api.fitbit.com/1/user/-/activities/date/YYYY-MM-DD.json
"summary": {
"activityCalories": 3468,
"caloriesBMR": 1774,
"caloriesOut": 4601,
"marginalCalories": 2320
Clearly the caloriesOut element is NOT the total sum of activityCalories + caloriesBMR (which would be 5242 not 4601). For what it's worth I didn't manually log anything, all the data is from my tracker, though I also didn't start/stop activities on the tracker, so the activities it captured were just ones it deduced from the data.
I've also not found a definition for marginalCalories.
Hi @ammulder
Let me double-check with engineering on this. While the generalized calculation is caloriesOut = caloriesBMR + activityCalories, it's possible our internal algorithms changes a bit.
I don't have any historical information on what marginalCalories is. We did research this topic last year and worked with our research and engineering teams, but couldn't come up with a concrete answer at the time. I can look into it again.
Hi @Gordon-C , were you able to get a response from engineering?
I had to laugh a little, thinking, we're all developers here, maybe you can just post the code! 😉
Best AnswerI searched the forum for "marginalCalories", and I see a post elsewhere that this field is deprecated and should be ignored.
