12-05-2017 05:40
12-05-2017 05:40
we are trying to read fitbit activity data for authorised user, using FITBIT WEB API, IMPLICIT FLOW WITH Client Authorisation for this we are using.
1. Activity data and summary
https://api.fitbit.com/1/user/-/activities/date/2017-10-27.json
"activities": [],
"goals": {
"activeMinutes": 30,
"caloriesOut": 2717,
"distance": 5.05,
"floors": 10,
"steps": 6000
"summary": {
"activeScore": -1,
"activityCalories": 811,
"calorieEstimationMu": 2100,
"caloriesBMR": 1643,
"caloriesOut": 2349,
"caloriesOutUnestimated": 2349,
"distances": [{
"activity": "total",
"distance": 5.47
"activity": "tracker",
"distance": 5.47
"activity": "loggedActivities",
"distance": 0
"activity": "veryActive",
"distance": 0.06
"activity": "moderatelyActive",
"distance": 0.87
"activity": "lightlyActive",
"distance": 4.53
"activity": "sedentaryActive",
"distance": 0
"elevation": 18.29,
"fairlyActiveMinutes": 15,
"floors": 6,
"heartRateZones": [{
"caloriesOut": 74.1715,
"max": 93,
"min": 30,
"minutes": 62,
"name": "Out of Range"
"caloriesOut": 1426.375,
"max": 130,
"min": 93,
"minutes": 645,
"name": "Fat Burn"
"caloriesOut": 13.46498,
"max": 158,
"min": 130,
"minutes": 2,
"name": "Cardio"
"caloriesOut": 0,
"max": 220,
"min": 158,
"minutes": 0,
"name": "Peak"
"lightlyActiveMinutes": 168,
"marginalCalories": 438,
"restingHeartRate": 95,
"sedentaryMinutes": 1256,
"steps": 7618,
"useEstimation": true,
"veryActiveMinutes": 1
Here: "activities": [] is always empty where as the fitbit doc says it must have the list of activities recorded.
2. Activity Log
https://api.fitbit.com/1/user/-/activities/list.json?afterDate=2017-10-27&sort=asc&offset=0&limit=20
in this api we are not getting distance information for activity with "auto-detect" key values.
Kindly provide solution for the same as we need to read the summary and activity details of user who authorize fitbit implicit flow.
Regards,
Best Answer01-15-2018 13:43
01-15-2018 13:43
You will need to use the Activity Timeseries API documented here - https://dev.fitbit.com/build/reference/web-api/activity/#activity-time-series but also need intraday data access. See the "Get Activity Intraday Time Series" section for details about getting access to intraday data.
01-03-2018 03:14
01-03-2018 13:37
01-03-2018 13:37
Sorry for the confusion, but the term "Activity" here has a specific meaning and is different from general user "activeness" throughout the day (which is represented in the summary section).
An "activity" (one that will show up in the "activities": array response value) represents a recorded activity such as a workout or a run that was either started/stopped manually or automatically detected and logged. Normal actions, such as walking that aren't explicitly marked by the user as a named activity (ie yoga, running, weightlifting) will not show up as an activity in this API.
Please let me know if I misunderstood your question or you have further questions.
Thanks,
Chris
Best Answer01-15-2018 02:14
01-15-2018 02:14
Thank you @ChrisMFitbit for your reply,
So let me just make sure I understand: If we want to know the user's number of steps per hour, we should use another API for that or does this resolution is simply not provided?
thanks,
Lior
01-15-2018 13:43
