10-01-2016 11:32
10-01-2016 11:32
I'm currently developing a plugin using the Fitbit's API. It worked fine up until I added a CURL request which takes the access key and uses it to make a request for the access token. Here's how the page work currently:
1. input your fitbit API details Press submit - this puts the access key in the site URL.
2. $_GET grabs the access key
3. A CURL script further down on the page uses that key to call for the access token.
Parts 1, 2 and 3 worked fine up until adding the CURL. I'm wondering if anyone can see where I'm going wrong. Here's the code for the post request - if I comment this out my $_GET query gives me a valid access key, but if I put this back on the page it seems to mess up what is in the address bar to get:
$urlcode = "https://api.fitbit.com/oauth2/token";
$access_token_settings = array(
'code' => $thecode,
'grant_type' => "authorization_code",
'client_id' => $clientid,
'client_secret' => $secret,
'redirect_uri' => $callback);
$auth_headers = array("Content-Type: application/x-www-form-urlencoded", "Authorization: Basic {$auth}");
$curlcode = curl_init($urlcode);
curl_setopt($curlcode, CURLOPT_HTTPHEADER, $auth_headers);
curl_setopt($curlcode, CURLOPT_POST, true);
curl_setopt($curlcode, CURLOPT_POSTFIELDS, http_build_query($access_token_settings));
curl_setopt($curlcode, CURLOPT_RETURNTRANSFER, true);
curl_setopt($curlcode,CURLOPT_TIMEOUT,1000);
curl_setopt($curlcode, CURLOPT_SSL_VERIFYPEER, false);
$response = curl_exec($curlcode);
curl_close($curlcode);
$autharray = ( array ) json_decode($response, true);
echo $response;
10-03-2016 14:19
10-03-2016 14:19
What is the error you receive back from the Fitbit Web API? Can you capture the actual HTTP request (these are easier to debug than code)?
