Well. My problem is i get null, or empty value. normally if no data exists i gemet at least "hrv:[]" as initiator.
Best AnswerAlso, i do get hrv values, but empty response was a system crash as i did expect at least a empty key
Thank you! I've been able to reproduce this problem and have reported it to engineering. I'll let you know once I get an update from them.
Yes. I have seen the same problem with HRV, breathing rate, temperature and SpO2. I have bugs out for each of them. I believe I know where the problem exists, and the team is currently investigating it.
Hi @JHultman
From my testing, it seems HRV, Breathing Rate and temperature have been fixed. I'm checking on the status of breathing rate.
