Hi @ericmarnadi,
Here's the link to the documentation on using the refresh token to obtain a new access/refresh token pair: https://dev.fitbit.com/build/reference/web-api/oauth2/#refreshing-tokens.
Basically, you'll follow similar process for obtaining the access token by executing
POST https://api.fitbit.com/oauth2/token
but, instead you'll specifying the grant_type = refresh_token, your refresh token and the expiration time. Here's an example of what that would look like
Authorization: Basic Y2xpZW50X2lkOmNsaWVudCBzZWNyZXQ=
Content-Type: application/x-www-form-urlencoded
grant_type=refresh_token&refresh_token=abcdef01234567890abcdef01234567890abcdef01234567890abcdef0123456
In this example, we didn't specify the expiration time. Therefore, the default expiration time of 28800 seconds or 8 hours will be used.
Gordon
