01-07-2026 06:51
01-07-2026 06:51
I have generated a valid token for my account and now when I use the api for fetching my watch data, it shows a generic data response for any date that I provide. could you please help if i am missing something
01-07-2026 13:03
01-07-2026 13:03
Hi @waqasK
Thanks for reaching out.
To help me figure out why you are seeing generic data instead of your actual stats, could you please provide:
The exact endpoint URL you are trying to call.
A snippet of the JSON response you are currently receiving.
Once I see those, I can determine if this is a permission scope issue or a data sync delay.
01-08-2026 11:51
01-08-2026 11:51
ok here is my entpoint url:
https://api.fitbit.com/1/user/-/activities/heart/date/$formattedDate/1d.json
Here is the response I get for any date I pass:
Activities Heart Response : {activities-heart: [{dateTime: (date removed due to the error while posting here), value: {customHeartRateZones: [], heartRateZones: [{caloriesOut: 1253.97786, max: 113, min: 30, minutes: 1440, name: Out of Range}, {caloriesOut: 0.0, max: 140, min: 113, minutes: 0, name: Fat Burn}, {caloriesOut: 0.0, max: 173, min: 140, minutes: 0, name: Cardio}, {caloriesOut: 0.0, max: 220, min: 173, minutes: 0, name: Peak}], restingHeartRate: null}}]}
Note: I pass the user token in header as required otherwise the endpoint won't respond with data. thank you
