Hi
I was trying to authenticate my app with fitbit's api using a sample app provided by auth.io (https://github.com/oauth-io/oauth-android). I add an extra button to connect with the provider "fitbit":
fitbitButton.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v){
o.popup("fitbit", MainActivity.this);
});I've also added fitbit as a provider in my oauth.io-account.
So when I launch my app it first looks like this:
Then I try to connect with fitbit:
After signing in I get this message and I have to push "back" to return to my app.
But after that nothing happens. I don't think the "onFinished" method is ever called. Does anyone know what the problem is? I'm pasting the full code below...
package com.example.oauth_example;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.URL;
import java.net.URLConnection;
import org.json.JSONObject;
import android.os.Bundle;
import android.os.StrictMode;
import android.app.Activity;
import android.graphics.Color;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
import io.oauth.*;
public class MainActivity extends Activity implements OAuthCallback { // implement the OAuthCallback interface to get the right information
Button facebookButton;
Button twitterButton;
Button fitbitButton;
TextView facebookText;
TextView twitterText;
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
final OAuth o = new OAuth(this);
o.initialize("MY KEY"); // Initialize the oauth key
facebookButton = (Button) findViewById(R.id.facebook);
twitterButton = (Button) findViewById(R.id.twitter);
fitbitButton = (Button) findViewById(R.id.fitbit);
facebookText = (TextView) findViewById(R.id.facebookText);
twitterText = (TextView) findViewById(R.id.twitterText);
facebookButton.setOnClickListener(new View.OnClickListener() { // Listen the on click event
@Override
o.popup("facebook", MainActivity.this); // Launch the pop up with the right provider & callback
twitterButton.setOnClickListener(new View.OnClickListener() {
@Override
o.popup("twitter", MainActivity.this); // Launch the pop up with the right provider & callback
@Override
o.popup("fitbit", MainActivity.this); // Launch the pop up with the right provider & callback
** Get the information
public void onFinished(OAuthData data) {
System.out.println(data.provider);
final TextView textview = data.provider.equals("twitter") ? twitterText : facebookText;
if ( ! data.status.equals("success")) {
textview.setTextColor(Color.parseColor("#FF0000"));
textview.setText("error, " + data.error);
// You can access the tokens through data.token and data.secret
textview.setText("loading...");
textview.setTextColor(Color.parseColor("#00FF00"));
// Let's skip the NetworkOnMainThreadException for the purpose of this sample.
StrictMode.setThreadPolicy(new StrictMode.ThreadPolicy.Builder().permitAll().build());
String provider;
if(data.provider.equals("facebook")){
provider = "/me";
}else if(data.provider.equals("twitter")){
provider = "/1.1/account/verify_credentials.json";
}else{
provider = "/oauth/request_token";
//provider = "/oauth/oauth_allow";
// To make an authenticated request, you can implement OAuthRequest with your prefered way.
// Here, we use an URLConnection (HttpURLConnection) but you can use any library.
data.http(provider, new OAuthRequest() {
private URL url;
private URLConnection con;
@Override
public void onSetURL(String _url) {
try {
url = new URL(_url);
con = url.openConnection();
} catch (Exception e) { e.printStackTrace(); }
@Override
public void onSetHeader(String header, String value) {
con.addRequestProperty(header, value);
@Override
public void onReady() {
try {
BufferedReader r = new BufferedReader(new InputStreamReader(con.getInputStream()));
StringBuilder total = new StringBuilder();
String line;
while ((line = r.readLine()) != null) {
total.append(line);
JSONObject result = new JSONObject(total.toString());
textview.setText("hello, " + result.getString("name"));
@Override
public void onError(String message) {
textview.setText("error: " + message);
When you get the oauth_verifier you need to do one last step, request access_token.
see https://wiki.fitbit.com/display/API/OAuth+Authentication+in+the+Fitbit+API for more details section: POST /oauth/access_token.
Since you're using oauth.io library you may need to read oauth.io's documentation on how to properly request access_token or debug the code to understand how to do that.
It is not too clear from the code why the onFinished icon is not called. You probably need to debug the code to understand how the oauth.io works.
Also beware the this is library is official one for oauth.io, and not for Fitbit. Althouth it may work it's not guaranteed it will work with Fitbit API.
