06-30-2014 10:29
06-30-2014 10:29
Hi,
I have been using the API succesfully with oauth until I recently needed to POST parameters to http://api.fitbit.com/1/user/-/profile.json Currently I get a 401 error for an invalid signature.
The odd things is that if I remove the parameters from the body of my request it works, even if i leave them hashed in the oauth header!
Here is an example of a signature that i generate:
POST&http%3A%2F%2Fapi.fitbit.com%2F1%2Fuser%2F-%2Fprofile.json&height%3D192.1%26oauth_consumer_key%3D2df33d655bf54344a670344a994e4b84%26oauth_nonce%3D726n44e8kbuminqp60kjemkfqs%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1404148709%26oauth_token%3D4c449b762a17dbec7ce22d1feb9edccc%26oauth_version%3D1.0
Here is what I use to add my parameters to the body(java):
String parameters = "height=192.1";
DataOutputStream wr = new DataOutputStream(conn.getOutputStream ());
wr.writeBytes(parameters);
wr.flush();
wr.close();
I assume that I am adding in the parameters incorrectly.
Thanks,
Liam
Best Answer06-30-2014 10:31
06-30-2014 10:31
Are you using an existing OAuth client such as signpost, scribe, etc?
Best Answer06-30-2014 10:33
06-30-2014 10:33
No I just wrote the code myself as it is fairly simply, and I haven't had any problems up to this point, I could add one of those libraries if i can't figure this out but I really don't want to
Best Answer06-30-2014 10:38 - edited 06-30-2014 10:39
We highly recommend using an existing client as OAuth 1.0 clients are more complicated than they appear. Using an existing client thats well tested will save you a lot of headache. (Theres also very good and easy to use clients for Java)
