01-27-2015 02:19
01-27-2015 02:19
i need to get data from Fitbit API with US unit measure my code has fix value in en_US but i receive Kilogram
it doesn't Pound.
private RestRequest CreateRestRequest(string apiCall, Method method = Method.GET)
var request = new RestRequest(apiCall, method);
// Always no cache
request.AddHeader("Cache-Control", "no-cache");
request.AddHeader("Accept-Language", "en_US");
return request;
}is these correct for add information on header ?
ps . My profile changed to 'Pound' when i scale on Aria.
Thank you. 🙂
Best Answer01-27-2015 11:49
01-27-2015 11:49
What exactAPI endpoint are you calling. I just tested https://api.fitbit.com/1/user/-/body/log/weight/date/<date>.json and it worked for me with Accept-Language: en_US header it responded in pounds.
01-27-2015 11:49
Best Answer01-27-2015 18:30
01-27-2015 18:30
i called 'API-Get-Time-Series' and respect type '[/body/weight]'.Before i call API i prepare request object like these. (below)
var request = CreateRestRequest(requestUrl);
request.OnBeforeDeserialization = resp =>
// Set root element
var data = (JsonObject) SimpleJson.DeserializeObject(resp.Content);
if (data != null && data.Any())
var root = data.FirstOrDefault();
request.RootElement = root.Key;
Best Answer01-27-2015 18:42
01-27-2015 18:42
i found my problem. Thank you for answer 🙂
the problem is 'wrong step of add header'.
