08-15-2014 10:34
08-15-2014 10:34
Hi!
In short:
This command works perfectly in terminal:
curl -i -X 'POST' -H 'Authorization: OAuth oauth_version="1.0",oauth_nonce="787c3d7a4e8dd140c8410f73ff9da863",oauth_timestamp="1408118970",oauth_consumer_key="636dxxxxxxxxxxxxxxxxxxx",oauth_signature_method="HMAC-SHA1",oauth_signature="Zy5tqSX32Zv8mQc5gZJXnWsTIoY%3D"' 'https://api.fitbit.com/oauth/request_token'
But this PHP code doesn't:
$url = "https://api.fitbit.com/oauth/request_token";
$generatedHeader = 'Authorization: OAuth oauth_version="1.0",oauth_nonce="787c3d7a4e8dd140c8410f73ff9da863",oauth_timestamp="1408118970",oauth_consumer_key="636dxxxxxxxxxxxxxxxxxxx",oauth_signature_method="HMAC-SHA1",oauth_signature="Zy5tqSX32Zv8mQc5gZJXnWsTIoY%3D"';
$options = array(
CURLOPT_URL => $url,
CURLOPT_RETURNTRANSFER => true,
CURLOPT_SSL_VERIFYPEER => false,
CURLOPT_HTTPHEADER => array($generatedHeader),
CURLOPT_HEADER => false,
CURLOPT_VERBOSE => true
$curl = curl_init();
curl_setopt_array($curl, $options);
$response = curl_exec($curl);
$info = curl_getinfo($curl);
curl_close($curl);
var_dump($response);
This is the response I get from FitBit api server:
"errors":[{
"errorType":"oauth",
"fieldName":"oauth_signature",
"message":"Invalid signature: Zy5tqSX32Zv8mQc5gZJXnWsTIoY="
"success":false
Both Base String and the Signature generated in my code match those ones generated in the FitBit API Debug Tool.
Since I can get a response using the curl command in terminal, I think it sould be easy to do the same using the curl command inside a PHP environment.
Because of internal limitations I can't use the OAuth extension in my application. Do you have any example of how to implement it in PHP, using curl?
Kind regards,
Paulo Amaral
Best Answer08-15-2014 10:42
08-15-2014 10:42
I doin't see in your code that you're making a POST request.
Are you sure you're making POST and not GET ?
08-20-2014 05:16
08-20-2014 05:16
ibahdanau, thanks for your reply!
You are right, but I tryed that and was not the only issue.
Actually, I could put the oauth extension to work in my server, using one of the builds that I found here: http://windows.php.net/downloads/pecl/releases/oauth/ . Now, I am using the FitBitPHP class (https://github.com/heyitspavel/fitbitphp), which works like a charm.
Anyway, after posting I noticed that there is a pure php port of the FitBitPHP class, that doesn't need the OAuth extension: https://github.com/TheSavior/fitbitphp .
Regards
08-15-2014 10:42
08-20-2014 05:16
08-20-2014 05:16
Regards
