I'm looking to buy a smart cup this year https://www.myvessyl.com/ will FitBit site be able to sink up with this so i can keep all the data collected on me Fitbit dashboard?
Fitbit has subcription API that you can use to be notified when your fitbit data had changed.
Please check out https://wiki.fitbit.com/display/API/Fitbit+Subscriptions+API
If https://www.myvessyl.com/ is not integrated with Fitbit you'll have to write your own code tthat does it.
Development skills are required for that.
Best AnswerYa developer skills are non-existent here maybe when I get it you could give me a crash course on how to, or direct me to a youtube video on how to J
Unfortunately Fitbit does not provides crash courses.
You can also check out IFFFT is is integrated with Fitbit.
In case if https://www.myvessyl.com/ is also integrated with IFFFT you may be able to sync your myvessyl and Fitbit account.
