01-14-2019 08:18
01-14-2019 08:18
I am developing a mobile app that needs to display a user's fitbit data to them with additional data. As this is a mobile app and not a web application, I am confused about the process flow for fulfilling the OAuth 2.0 needs. On the fitbit registration screen, it is asking for a callback url, but as this is a mobile app, how would I provide a callback url or use it with my mobile app? For the subscription api process flow, would a user
1) login using the oauth 2.0 process,
2) approve the necessary permissions for my app,
3) a user activity or body metrics are measured by the fitbit device and uploaded to fitbit backend,
4) fitbit sends my app a notification that something new is available or would it just send the new data that is available?
Best Answer01-14-2019 13:59
01-14-2019 13:59
Hi @dever_node1,
Maybe some mobile application developers who read the forums can provide you with some details. From what I have seen, you should be able to register a URL for your mobile app (i.e. my://) and use that URL for your callback URL (i.e. myapp://callback).
The flow you've described is correct. In step 4, Fitbit will send your application a webhook notifying you that the Fitbit user has updated their activity or body data. The notification will look something like this.
"collectionType": "activities",
"ownerId": "22PT4L",
"ownerType": "user",
"subscriberId": "3",
"subscriptionId": "123"
The updated data does not appear in the notification. Instead, you will need to execute one of the activity or body endpoints to retrieve the updated data.
Best Answer01-14-2019 20:30
01-14-2019 20:30
Do you still have the same rate limits?
Best Answer01-17-2019 08:06
01-17-2019 08:06
Here is the current information on our rate limits: https://dev.fitbit.com/build/reference/web-api/basics/#rate-limits
