06-29-2016 23:14
06-29-2016 23:14
I can't seem to find this anywhere, so i apoligise if its been talked about before.
In your Trademark doc (https://dev.fitbit.com/trademark), there is the following
You may make truthful, factual references to Fitbit in plain-text prose descriptions of your Developer Applications’ features and benefits (including references to a Developer Application’s interoperability with Fitbit). For example, the FITBIT trademark can only be used in the manner shown in one of the referential descriptions below: "Designed for use with the FITBIT® platform" "For use with FITBIT® [insert particular feature/product name]" "Synchs with FITBIT® [insert particular feature/product name]" "Designed to interact with FITBIT® data" These phrases can appear near, but must be completely separate and apart from the name/logo of the Developer Application. The font size of phrases using the FITBIT mark should not be larger than the surrounding font, and should not appear more prominently than the name/logo of the Developer Application.
Is Synchs purposefully spelt incorrectly? As far as I am aware, in English is should be
"Syncs"
so therefore it would be
"Syncs with FITBIT® [insert particular feature/product name]"
Any advice in terms of this would be great.
Cheers
06-29-2016 23:50
06-29-2016 23:50
"Syncs" is cool with us. 🙂
06-29-2016 23:50
06-29-2016 23:50
06-29-2016 23:56
06-29-2016 23:56
Awesome!
Thankyou
