Fitbit team:
When trying to retrieve the Access Token, I'm getting the following error:
"errors":
"errorType":"oauth",
"fieldName":"n/a",
"message":"oauth_problem=parameter_rejected&oauth_parameters_rejected=oauth_signature
...oauth_version...oauth_nonce...oauth_signature_method...oauth_token...oauth_timestamp
Http status code: Unauthorized
Any ideas what the problem could be?
Sidenote: This happens the first time we try to connect the Fitbit application. The next time (apparently, after the user has logged in) the access token can be retrieved.
This occurs using OAuth 1.0a.
This issue is happeing in a staging environment and I cannot get the request we are sending.
Based on this information, do you have any idea what's wrong?
I know parameter_rejected seems to be something wrong with the request, but we construct all requests the same way and it is weird.
Thanks,
Bruno
