12-19-2014 08:41
12-19-2014 08:41
Hi there,
I am trying to read data using WebUI in a java standalone code. I get an error:
Exception in thread "main" org.scribe.exceptions.OAuthException: Response body is incorrect. Can't extract token and secret from this: 'oauth_problem=permission_denied'
at org.scribe.extractors.TokenExtractorImpl.extract(TokenExtractorImpl.java:41)
at org.scribe.extractors.TokenExtractorImpl.extract(TokenExtractorImpl.java:27)
Looks like - this error is originated at "Token accessToken = service.getAccessToken(requestToken, v);". Can anyone point, what is the problem with the code. what is needed to be corrected.
Following is the code
package com.euphoria.fitness;
import org.scribe.builder.ServiceBuilder;
import org.scribe.builder.api.FitbitApi;
import org.scribe.model.OAuthRequest;
import org.scribe.model.Response;
import org.scribe.model.SignatureType;
import org.scribe.model.Token;
import org.scribe.model.Verb;
import org.scribe.model.Verifier;
import org.scribe.oauth.OAuthService;
public class FitBit {
public static void main(String[] args){
OAuthService service = new ServiceBuilder()
.provider(FitbitApi.SSL.class)
.apiKey("646d1c99e1fe45b49db573784ef03a89")
.apiSecret("61540eecfdf047059bdb486d7b1b1786")
//.signatureType(SignatureType.QueryString)
.debug()
.build();
Token requestToken = service.getRequestToken();
String authUrl = service.getAuthorizationUrl(requestToken);
String token = authUrl.substring(authUrl.indexOf("=")+1);
System.out.println();
System.out.println("<<<<<<<<<>>>>>>>>>>>> "+authUrl);
Verifier v = new Verifier(authUrl);
OAuthRequest request = new OAuthRequest(Verb.GET, "https://api.fitbit.com/1/user/-/profile.xml");
service.signRequest(accessToken, request); // the access token from step 4
Response response = request.send();
System.out.println(response.getBody());
12-19-2014 23:50
12-19-2014 23:50
Hi,
I did a little hack... I wrote JSoup code to post authentication request yo get PIN.
//String token="605c93ef8c3200926dc996d97e99b8e3";
Document doc = Jsoup.connect("https://api.fitbit.com/oauth?oauth_token="+token+"&locale=&display=&authentication=&oauth_allow=Allo...
//System.out.println(doc.text());
Element form =doc.select("form[id=oauth_login_form]").first();
System.out.println("oauth_token = "+form.select("input[name=oauth_token]").val());
System.out.println("locale="+form.select("input[name=locale]").val());
System.out.println("oauth_allow="+form.select("input[name=oauth_allow]").val());
System.out.println("_sourcePage="+form.select("input[name=_sourcePage]").val());
System.out.println("__fp ="+form.select("input[name=__fp]").val());
String url ="https://api.fitbit.com/oauth/oauth_login_allow?"
+ "oauth_token="+form.select("input[name=oauth_token]").val()
+ "&locale="+form.select("input[name=locale]").val()
//+ "&oauth_allow="+form.select("input[name=oauth_allow]").val()
+ "&_sourcePage="+form.select("input[name=_sourcePage]").val()
+ "&__fp="+form.select("input[name=__fp]").val()+
"&email=<YYYYYYYY>&password=<XXXXXX>";
System.out.println(url);
Document responseDoc=Jsoup.connect(url).post();
String vToken = responseDoc.select("div.pincode").first().text();
After I got the token and passed the same to Verifier and working like a charm.
Can any one suggest any other better way to do this?
Regards,
Sreeram MC
12-19-2014 08:45
12-19-2014 08:45
Please make sure that the token is not expired.
Try to issue new token and see what happens.
12-19-2014 09:06
12-19-2014 09:06
Ivan Bahdanau,
Thank you for lightening response.
I am passing the token that I fetched from previous step and passing it. Are you suggesting that timestamp used is the issue? or Token is expired?
Following is the Scribe log:
obtaining request token from https://api.fitbit.com/oauth/request_token
setting oauth_callback to oob
generating signature...
using base64 encoder: CommonsCodec
base string is: POST&https%3A%2F%2Fapi.fitbit.com%2Foauth%2Frequest_token&oauth_callback%3Doob%26oauth_consumer_key%3D646d1c99e1fe45b49db573784ef03a89%26oauth_nonce%3D2989727642%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1419008539%26oauth_version%3D1.0
signature is: fVKoKeobs9jQDhCWbmapiFt4udU=
appended additional OAuth parameters: { oauth_callback -> oob , oauth_signature -> fVKoKeobs9jQDhCWbmapiFt4udU= , oauth_version -> 1.0 , oauth_nonce -> 2989727642 , oauth_signature_method -> HMAC-SHA1 , oauth_consumer_key -> 646d1c99e1fe45b49db573784ef03a89 , oauth_timestamp -> 1419008539 }
using Http Header signature
sending request...
response status code: 200
response body: oauth_token=2768f0537ce4de92d31830d5d76dcaa1&oauth_token_secret=66014dda72cc1e2bbee22995c3a5d40a&oauth_callback_confirmed=true
<<<<<<<<<>>>>>>>>>>>> https://api.fitbit.com/oauth/authorize?oauth_token=2768f0537ce4de92d31830d5d76dcaa1
obtaining access token from https://api.fitbit.com/oauth/access_token
setting token to: Token[2768f0537ce4de92d31830d5d76dcaa1 , 66014dda72cc1e2bbee22995c3a5d40a] and verifier to: org.scribe.model.Verifier@15ca232
base string is: POST&https%3A%2F%2Fapi.fitbit.com%2Foauth%2Faccess_token&oauth_consumer_key%3D646d1c99e1fe45b49db573784ef03a89%26oauth_nonce%3D2365128259%26oauth_signature_method%3DHMAC-SHA1%26oauth_timestamp%3D1419008541%26oauth_token%3D2768f0537ce4de92d31830d5d76dcaa1%26oauth_verifier%3Dhttps%253A%252F%252Fapi.fitbit.com%252Foauth%252Fauthorize%253Foauth_token%253D2768f0537ce4de92d31830d5d76dcaa1%26oauth_version%3D1.0
signature is: AnXNMT6T1xvsNDfis1hOqsGbnkA=
appended additional OAuth parameters: { oauth_signature -> AnXNMT6T1xvsNDfis1hOqsGbnkA= , oauth_version -> 1.0 , oauth_nonce -> 2365128259 , oauth_signature_method -> HMAC-SHA1 , oauth_consumer_key -> 646d1c99e1fe45b49db573784ef03a89 , oauth_token -> 2768f0537ce4de92d31830d5d76dcaa1 , oauth_verifier -> https://api.fitbit.com/oauth/authorize?oauth_token=2768f0537ce4de92d31830d5d76dcaa1 , oauth_timestamp -> 1419008541 }
at org.scribe.oauth.OAuth10aServiceImpl.getAccessToken(OAuth10aServiceImpl.java:104)
at org.scribe.oauth.OAuth10aServiceImpl.getAccessToken(OAuth10aServiceImpl.java:85)
at org.scribe.oauth.OAuth10aServiceImpl.getAccessToken(OAuth10aServiceImpl.java:90)
at com.euphoria.fitness.FitBit.main(FitBit.java:34)
12-19-2014 20:15
12-19-2014 20:15
Hi,
Look like I am not getting PIN from the following call:
I have registered this as a desktop application. Can any one please let me know how I can get the token in a standalone applicaiton, which is not browser based app.
Regards,
Sreeram MC
12-19-2014 23:50
12-19-2014 23:50
Hi,
Regards,
Sreeram MC
01-14-2015 00:12
01-14-2015 00:12
Dear Sreeram MC
i try your workaround and it succefully send the request and response is 200 (ok ) but with null body in get profile data ,can you tell me the cause for that ??
