Hi,
I've been getting timeout for activityCalories. Is this a known problem?
https://api.fitbit.com/1/user/-/activities/activityCalories/date/today/max.json
Thanks
Best AnswerBonxy, thanks for confirming it's slow for you too.
For me, this API took about 30 seconds, then returned 504 HTTP error. It doesn't seem normal, because all the other Fitbit API are returning data pretty fast (within 3 seconds)
Best AnswerYes I'm going to change max to something like 1m as the last option.
But before that, want to post here to know if there's an API bug, to cause this specific API to be slow. All the other API are very fast with max; also I'm using max only for the very first time of usage, subsequent API usage are incremental.
