07-15-2015 19:36
07-15-2015 19:36
Hi,
I am using custom code to communicate with fitbit, using OAuth1.0 for authentication. I am able to get to the point where i can get steps A-E done and G for end points not involving parameters.
I am getting 401 error with "Invalid signature" response, on building the signature with GET parameters.
{"errors":[{"errorType":"oauth","fieldName":"oauth_signature","message":"Invalid signature: M0q/T+b+lBT8XMqhCDyloy2yR7E="}],"success":false}
I have tried to build the signature with and without the parameters in the url part.
(PS: my application does not allow me to use 3p packages)
Quick help is really appreciated.
Best Answer07-16-2015 12:14
07-16-2015 12:14
The OAuth 1.0a signature is computed with both URL and body parameters precisely per the RFC 5849 protocol. If you cannot use a third-party library, you should examine a third-party library closest to the programming language that you are using and compare each step of the signature creation process using our OAuth 1.0a debug tool.
07-16-2015 12:14
