03-10-2016 00:19
03-10-2016 00:19
I am using auth0 to authenticate fitbit in swift. I am able to get the access_token and id_token and user profile info using auth0 api. But when I make request to fitbit api I get an error stating invalid token. Please Help!!
03-10-2016 10:17
03-10-2016 10:17
We can't debug your application, but if you share the HTTP request that your app is actually making and the response, we can help identify the issue. You can use a tool like Runscope Traffic Inspector.
Best Answer03-10-2016 23:51
03-10-2016 23:51
I am getting this error:
errors = (
errorType = "invalid_token";
message = "Access token invalid: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczovL215Zml0YXBwLmF1dGgwLmNvbS8iLCJzdWIiOiJmaXRiaXR8NDI5TlBHIiwiYXVkIjoiTkRzZ2pZRGZNUFd3d2M1MTNPbTREcUdXS2FDOTNHZDIiLCJleHAiOjE0NTc3MTgyNTMsImlhdCI6MTQ1NzY4MjI1M30.7hR0r24Ztq9wiIr_y2SSQhyFkhDs1g0Rj-8SkNGytm8. Visit https://dev.fitbit.com/docs/oauth2 for more information on the Fitbit Web API authorization process.";
success = 0;
The request I am making is:
let targetURLString = "https://api.fitbit.com/1/user/-/profile.json"
let request = NSMutableURLRequest(URL: NSURL(string: targetURLString)!)
request.HTTPMethod = "GET"
request.setValue("Bearer \(idToken!)", forHTTPHeaderField: "Authorization")
let session = NSURLSession(configuration: NSURLSessionConfiguration.defaultSessionConfiguration())
let task: NSURLSessionDataTask = session.dataTaskWithRequest(request) { (data, response, error) -> Void in
do{
let dat = try NSJSONSerialization.JSONObjectWithData(data!, options: NSJSONReadingOptions.MutableContainers) as! NSDictionary
NSUserDefaults.standardUserDefaults().setObject(dat, forKey: "dataDictionary")
NSUserDefaults.standardUserDefaults().synchronize()
print(dat)
catch{
print("Could not convert JSON data into a dictionary.")
task.resume()
Best Answer07-07-2017 10:08
07-07-2017 10:08
Im having the exact same error using Auth0. Were you able to find a solution?
