Sometimes api.fitbit.com resolves to 104.16.66.50 and sometimes it resolves to 104.16.65.50. Attempts to connect to 104.16.65.50 on port 443 have been timing out since yesterday afternoon, only from one of my hosts.
nslookup returns the following.
$ nslookup api.fitbit.com
Non-authoritative answer:
api.fitbit.com canonical name = api.fitbit.com.cdn.cloudflare.net.
Address: 104.16.66.50
Address: 104.16.65.50
This always works, when api.fitbit.com resolves to .66
$ telnet api.fitbit.com 443
This never works, when api.fitbit.com resolves to .65
12-04-2015 10:37 - last edited on 01-19-2016 11:48 by JeremiahFitbit
Yes, still experiencing the problem.
$ date
Fri Dec 4 12:29:08 CST 2015
worked
$ telnet 104.16.65.50 443
Trying 104.16.65.50...
Connected to 104.16.65.50.
Escape character is '^]'.
5 seconds later, did not work
5 seconds later, still not working
1 minute later, works again
a few seconds later, timeouts again.
Can you confirm a firewall or IDS is not blocking traffic? I emailed you earlier today with my source IP address, application names, and client IDs.
Edit: removed email address
Best AnswerI seeing the same thing. After tracing the requests, it appears the cloudfare is putting up a capatcha screen (i.e. go to https://client.fitbit.com/tracker/client/message in your browser) - even if you set pass the capatcha and it sets the cookie in the browser, the app or my phone on wifi will continue to fail as cloudflare is blocking the connection.
@goodes: If you're making a high volume of requests, CloudFlare may do this. Contact us privately and we can look into it.
