10-20-2016 22:01
10-20-2016 22:01
10-21-2016 04:02
10-21-2016 04:02
A warm welcome to the Community @Stinna90. Sometimes the side spring may be bent as a result of improper battery insertion or pressure being applied to the back housing. I recommend verifying that there is proper contact between the battery and the battery contacts inside your Zip tracker. You can do this by opening the battery door of your Zip, removing your battery, and ensuring that the silver battery tab located in the lower right half of your tracker is flush with the white box outline in the tracker housing. The process can be followed here.
I hope this helps, let me know how it goes.
10-22-2016 05:59
10-22-2016 05:59
10-24-2016 18:47
10-24-2016 18:47
11-02-2016 05:28
11-02-2016 05:28
11-02-2016 05:33
11-02-2016 05:33
Those are great news @Stinna90, @Mimimack and @Sandramaynard welcome to the Community! I am glad to hear that the instructions provided worked and that your Zip is now working properly. @Sandramaynard Have you tried the instructions I provided in my previous post? If you haven't, please follow those tips.
Catch you later.
11-02-2016 11:10
11-02-2016 11:10
11-03-2016 05:33
11-03-2016 05:33
Hi there @Stinna90 the battery of the Zip should last at least up to 6 months, if the period you need to change battery is shorter, I recommend to make sure the battery is doing proper contact as was recommend before on a previous post. THis is the most common cause when the battery is failing.
If the issue persists with your Zip, feel free to contact our Support Team for additional help.
See you around and if you have more questions let me know.
11-03-2016 22:34
11-03-2016 22:34
11-17-2016 10:15
11-17-2016 10:15
Hi @Stinna90. Good to see you in the Community! 🙂
I'm sorry that your battery was not lasting for much long but I'm happy to hear that you were able to get another tracker that works better.
In situations where you've already tried the basic troubleshooting steps to no avail, it's always better to get in touch with the Support Team for them to be able to help you out!
Anything else, let us know!
