04-01-2016 18:52
04-01-2016 18:52
I have had my zip for a month. Yesterday it had a blank screen even after tapping it so figured it must have had a dodgy battery and replaced it. Still have a blank screen. Every now and then for no reason the screen will display for a second or two then go blank again. I can't seem to get it to do anything.
Has anyone else had the same issue? What can I do?
I have contacted customer support but thought I would try in here as well.
Best Answer04-01-2016 19:02
04-01-2016 19:02
04-01-2016 19:02
check these contacts.
Best Answer04-01-2016 19:14
04-01-2016 19:14
I did try playing with the contacts before but obviously I didn't play with the little one enough as it seems to be working now. Thank you!
04-02-2016 08:50
04-02-2016 08:50
Best Answer04-05-2016 20:26
04-05-2016 20:26
My zip is a month old and it stop working. I tried the troubleshoot that has been suggested by it didn't owrk. Do you have any other suggestion?
Best Answer04-08-2016 12:41
04-08-2016 12:41
Hey you @sblady99
, hope you're doing great! Hmmm... if you have tried the suggestions that my friend @Rich_Laue has shared with no luck, I'd recommend getting in touch with Customer Support directly so they can give you a hand on this.
Good news my friends @Scdc @Hopetown56, I'm glad to hear you both are back in business!
Happy stepping!
