01-30-2018
13:03
08:35
LucyAP
01-30-2018
13:03
08:35
LucyAP
What's with this rapid battery drain issue Fitbit? This time I got 23 days. Plus it refused to sync yesterday but is today. Its all getting worse instead of better.
Best Answer02-01-2018 11:58
02-01-2018 11:58
Welcome to the Forums @SunsetRunner! Thank you for sharing your experience with Fitbit Zip. Also, I really appreciate all the time and effort you have invested with this issue. Our engineering team is aware of the battery issues that at the moment some Zip users might been experiencing. Be assured that they are working to solve this as soon as possible.
In the meantime, please double check that:
Also, make sure that you are following the main thread for this issue Zip rapid battery drain on iOS version 2.41.1.
Regarding your syncing issues, take a look to these steps to fix your syncing issues with the iOS app. If this doesn't work, follow the help article Why won't my Fitbit device sync?
I hope this helps, keep me posted! 😉
