Hey @Nikkibsocute. Hmmm it could be that the battery compartiment is not holding the battery tight enough to keep a good connection and this is causing the tracker to reset. I would recommend pulling up the little metal plate on the back of the tracker to make sure it will make a proper connection with the battery and also everytime you change the battery, try to sync your Zip to make sure you will not lose any information.
Hope this helps and if you notice this keeps happening, feel free to get in touch with the Support Team and they will be happy to help you out.
Let me know if you need anything else! Welcome to the Forums. 🙂
