08-05-2018
14:16
06:45
YojanaFitbit
08-05-2018
14:16
06:45
YojanaFitbit
How do I change Zip sync to IPad from IPhone?
Moderator edit: Updated subject for clarity.
08-12-2018 09:21 - edited 08-14-2018 04:52
Nice to see that you're digging into the Forums @wfinger111.
Thanks for sharing the issues that you've been having with your iPad. To find the Fitbit App please change the options iPad only into iPhone only, since the Fitbit App is visible only for iPhones.
Hope this helps.
08-07-2018 06:32 - edited 08-07-2018 06:39
Welcome aboard my friend @wfinger111!
About your inquiry, you can sync from your iPhone in the same way you sync from your iPad; just make sure it is listed here and if you have doubts about it follow the instructions in this article: How do I manually sync my tracker? (iPhone or iPad).
Is this what you need?
Please let me know if you need more help.
08-08-2018 05:44
08-08-2018 05:44
Thanks for your response. My iPad Fitbit Dashboard does not have the : "Account Box" to bring up manual sync. Also, when I try to download the Fitbit app to get a newer version, all I get are third-party app sellers for "Find your Fitbit", etc.in the IPad App Store. Is this normal?
Hope this helps.
