01-07-2017 17:25
01-07-2017 17:25
Why does my Zip change the distance I've walked from the end of my walk to when I get in the house (maybe 10 yards)?
01-17-2017 08:33
01-17-2017 08:33
Hello @Cacti, thanks for joining us, it's great to have you on board!
If you notice a big discrepancy on the distance your Zip is measuring I would like to suggest performing an accuracy test. To perform the test you will first need to restart your tracker:
To restart your tracker:
After restarting:
If your tracker counted less than 100 steps or more than 100, my best recommendation would be contacting our Support Team. Let them know about the test you've performed, I'm sure they will be more than happy to get you back on track.
Give it a try and keep me posted in case you need anything else!
