09-16-2016 11:40
09-16-2016 11:40
Best Answer09-18-2016 15:04 - edited 09-18-2016 15:05
@BeckyJo welcome to the forums! Well, in this case, please go to your weight log on your Dashboard and to log weight for previous days, just select the drop down menu for the calendar and enter your weight accordingly. Just like this:
Hope this helps. Keep me posted! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
09-18-2016 15:18
09-18-2016 15:18
09-20-2016 12:13
09-20-2016 12:13
@BeckyJo you are very welcome! I'm so glad to read that I was able to help!
Let me know if you have any other inquiry, I'll be happy to help you out! ![]()
Best Answer02-05-2021 19:15
02-05-2021 19:15
Related que
Best Answer02-05-2021 19:25
02-05-2021 19:25
Related question: I would like to enter a weight from start of weight loss program. Drop down calendar appears to only go back 3 visible months, e.g. February, January, December. Unable to enter Nov. 11 starting weight. How do I get this weight entered?
