I had to change the battery in my FitBit zip a few days ago and now it will not reset at midnight. The internal clock is about 90 minutes behind also. I am not sure what to do. I tried to reset again but removing the battery, waiting for 10 seconds, and inserting it again. It still does not reset correctly. I have to track points daily so I need to get this corrected.
Awesome help @Rich_Laue! 😉 Nice to see you here @SheilaDS! @Rich_Laue Kindly suggested you to sync your tracker in order to fix your clock. Once you fix your timezone setting on the system and sync your tracker will reflect this change. If you have any issue syncing your tracker, please follow this post on how to fix syncing issues.
Catch you later! 😉
