09-22-2016 20:02
09-22-2016 20:02
Best Answer09-24-2016 07:51
09-24-2016 07:51
Hi @Lozv1, it is great to see new faces around the Community!
Depending if you are a right or left handed person, it will affect the amount of steps. For example, if you are a right handed person, you have to use your tracker on the other hand and viceversa. Now lets see, you are using the Fitbit Zip and the Fitbit Charge HR at the same time, right? We don't recommend you to compare the results of both tracker because the way they track is different, remember that the Charge HR records your steps using the movement of your arms, so I can tell you that is pretty accurate, but you can get some extra steps.
Let me know if you have further questions!
09-25-2016 01:14
09-25-2016 01:14
Best Answer09-26-2016 05:58
09-26-2016 05:58
Thanks for getting back to me @Lozv1! Well, we don't recommend you to use the Charge HR in your ankle because It is not designed to be wear there. It'll count your steps but not as accurate as if you were correctly using it, which is on your wrist (depending if you are right or left handed). Now regarding the Zip, it is a pretty basic tracker but pretty accurate, but as you mentioned, the Charge HR is a little bit more accurate than that one, since it is using a better and more advanced technology to get better results.
I'll be around if you have other questions!
