11-06-2016 05:18 - last edited on 11-24-2016 05:11 by AndreaFitbit
If you forget to sync the zip for some days, will the zip remind you to sync after 30 days? Or will you have to remember yourself to sync the zip with the app, to avoid to loose steps in you history?
11-06-2016 07:19
11-06-2016 07:19
You have to remember yourself, there are no reminders.
Also, note that you start losing data if you don't sync for 7 days:
Taken from: https://help.fitbit.com/articles/en_US/Help_article/1374/
11-06-2016 07:19
11-06-2016 07:19
