09-22-2017 11:03
09-22-2017 11:03
Hi
can anyone tell me if this device is compatible with iPhone 7?
cheers
Best Answer09-22-2017 18:50
09-22-2017 18:50
Thanks for visiting the Community @SunsetRunner! The iPhone 7 is a compatible device. For further information about which features you’ll get with the Fitbit app you can check our compatible devices list.
Also, you can check here the User Manual for the Fitbit Zip for extra information about it.
I hope this helps, keep me posted! 😉
